Futaba 2.4
Futaba 2.4
I cannot down load the software to connect my Radio to the Heli-X , any hint where I can access it?
Re: Futaba 2.4
I am trying to use this web address but it is not working: http://n.ethz.ch/student/mmoeller/fms/down.html
So far I can not use the Heli-X
Re: Futaba 2.4
Uhm, what is the setup you try to run?
Assume you have a Futaba radio and try to run Heli-X? If so, the FMS link won't help (FMS is a different simulator). On the other hand you don't need a special software to connect the Futaba with Heli-X, just a suitable USB connector cable.
Maybe for special setups on non common OS PCs you may need some according installation or additional drivers but afaik on Win/Mac it is all pretty simple.
