Heli-X shuts down after Language selection with Java error
brassing
Post by brassing »
I have tried Heli-X 5 and 4 demos and in both cases the program shuts down right after selecting a language (English). The error log is below. It blames Java runtime. Any suggestions? I have the program installed in the Program Files folder not directly under C: , if that make any difference. I am running Windows XP 32 bit.
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6ce26324, pid=11848, tid=13612
# JRE version: 7.0_07-b11
# Java VM: Java HotSpot(TM) Client VM (23.3-b01 mixed mode windows-x86 )
# Problematic frame:
# C [DINPUT8.dll+0x16324]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
