The rotor disc looks too much like a disc, not like in real life. Is there a way to make it almost invisible?
t.
Rotor disc visibility
Re: Rotor disc visibility
look for the file Mainrotor.obj in the folder of the heli. There you find the name of the corresponding .mat file. Inside of this file you find the path of the textures. You can modify the alpha channel of these pictures to modify the transparency.... Needs some experience, though.
Thanks. I can't figure out how to do it (I'm no gimp wizard), and I would have to repeat it for every helicopter.
I Was hoping for a way to turn the rotor visibility down on all models at once. In phoenix-sim, it's done by just pulling a slider to the left.
torben
torben
