Buttons and flight modes and special functions
Posted: 08 Aug 2015 20:47
A couple of questions.
- I'm using my radio as the controller in the 5 channel mode (finally that I have a working adaptor). I'm using curves, expo settings and dual rates in the radio, not in the heli settings. I'm using the radio flight mode switch. As a result, Hel-X has no idea which mode I'm in, as the flight mode switch does not directly correspond to any input. Is this an intended mode of operation?
- The radio has toggle switches, not push buttons. I try to assign the start/stop recording function to a switch. However when I toggle the switch on, Heli-X interprets this as a push button being pushed continuously, and then proceeds to start and stop recording every second or so. The workaround is to flick the switch on and off quickly, so that Heli-X only registers one "button push". Is there a more direct method? Perhaps there should be a way to assign actions to "on" and "off" events separately.
