1735 Release Candidate 2
Post by Michael » 18 Jan 2018 20:28
it seems V7 is stable. No problems were found so far. You may update to 1735 (within HELI-X). I added the possibility to display the HELI-X logo. This seens to be important for forthcoming videos, etc.
Thank you for help with testing.
tdahbura
Re: 1735 Release Candidate 2
Post by tdahbura » 22 Jan 2018 03:02
I just installed a demo version of 1735 on osx high sierra. It is not detecting my transmitter that worked fine with heli-6.1.1651.
Thanks,
Tony
tdahbura
Post by tdahbura » 22 Jan 2018 03:20
upgrading java-am on version 9.0.4 the program is not complaining about the controller now, but the sticks are not responding in the program. When in the setup of the controller the sticks do not move at all when the sticks are moved on the connected transmitter.
Just wanted to update you on the status.
Thanks,
Tony
Post by Michael » 22 Jan 2018 07:08
Change the input system: global options->input system.
tdahbura
Post by tdahbura » 23 Jan 2018 01:49
I made no changes today and was able to get the controller to respond. Not clear what was going on with this yesterday.
Once I am comfortable that 7 is stable will be in touch to purchase.
Thx
danieldh206
Post by danieldh206 » 02 Feb 2018 23:15
Windows 10 Professional
Java with latest updates
Every time I try and toggle into full-screen Heli-X 7 1735 crashes and I get an Error while swapping buffers, IllegalStateException: Display not created
After I restart Heli-X I have to reselect the airport and helicopter.
I tried running as administrator but this did not work. I could not find a similar problem in the forums to fix this issue.
Thank you,
Daniel
Post by Michael » 03 Feb 2018 08:35
try different Screen resolutions in global Settings->OpenGL
