1734 Release Candidate
Post by Michael » 13 Jan 2018 09:17
Revision 1734 is now the release cadidate for the final Version 7. The documentation and some translations are still missing though. If you want to join the final beta test, you should fullfill the following requirements:
Windows/Linux: You are able to localize directories and you are able to delete files and/or directories.
macOS: You are able to localize your personal library folder and you are able to delete files and or directories.
Version 7 can be downloaded here: http://www.heli-x.info/cms/v7beta . If you want to acticate V7, send an email (not a message in the forum) and I will provide you a temporarly usable activation key and keep you informed about possible updates within the beta phase. V7 can be installed parallel to an installation of an older version of HELI-X. The feedback can be posted in this thread.
Best regards
ilyxa
Re: 1734 Release Candidate
Post by ilyxa » 14 Jan 2018 10:08
After update to 1734:
[ilyxa@wombat ~]$ java -version
openjdk version "1.8.0_144"
OpenJDK Runtime Environment (build 1.8.0_144-b01)
OpenJDK 64-Bit Server VM (build 25.144-b01, mixed mode)
[ilyxa@wombat ~]$ archlinux-java status
Available Java environments:
  java-8-openjdk/jre (default)
[ilyxa@wombat ~]$ /opt/HELI-X7/runHELI-X.sh
handleError
SEVERE o 12:06:58 PM Uncaught exception thrown in Thread[jME3 Main,6,main]
java.util.MissingResourceException: Can't find resource for bundle java.util.PropertyResourceBundle, key menuTracksNone
        at java.util.ResourceBundle.getObject(ResourceBundle.java:450)
        at java.util.ResourceBundle.getString(ResourceBundle.java:407)
        at net.HeliX.b.ax.g(Unknown Source)
        at net.HeliX.b.ax.<init>(Unknown Source)
        at net.HeliX.b.au.c(Unknown Source)
        at net.HeliX.b.ac.<init>(Unknown Source)
        at net.HeliX.b.au.<init>(Unknown Source)
        at net.HeliX.b.am.c(Unknown Source)
        at net.HeliX.b.am.<init>(Unknown Source)
        at net.HeliX.s.o.initialize(Unknown Source)
        at com.jme3.system.lwjgl.LwjglAbstractDisplay.initInThread(LwjglAbstractDisplay.java:130)
        at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.java:211)
[ilyxa@wombat ~]$
Test paltform for Beta: MacOSX 10.8 / MBP lat 11, Win 7 x64 / Lenovo X220 / MacOSX 10.9 / MBA late 12
Post by Michael » 14 Jan 2018 10:20
This is due to missing ressources due tot he different revisions. Please
Download the demo version from scratch and then activate ist. Does it work?
On macOS delete HELI-X7 in your personal library folder.
Juergen
Post by Juergen » 14 Jan 2018 11:18
Hi Michael,
it works great on my MacBook Pro without any problems.
Can fly the nativ 4K resolution on the external monitor with 60 frames (AA Off) :o
even though its only the onboard gpu and this is known manner not the best.
Jeti over USB was detected immediately. Really a great thing for me. Thank you.
Best regards
Jürgen
MacBook Pro 13" (2017), latest macOS 10.13.2
LG 4K USB-C Monitor, 3840x2160 @ 60 Hz
Jeti DS16 V4.23
ilyxa
Post by ilyxa » 14 Jan 2018 13:01
Michael wrote:
14 Jan 2018 10:20
Did it, work like a charm again! Thank you!
andreyk72
Post by andreyk72 » 14 Jan 2018 21:01
MacOS 10.11.6 : The V7 does not see Vbar Control radio as a joystick. The Heli-X version 6.1 has no such problem at the same time.
Post by Michael » 14 Jan 2018 21:31
Please try the different input systems (global options).
Does it work?
andreyk72
Post by andreyk72 » 14 Jan 2018 22:13
I've tried all the input systems and none of them worked. In the terminal however I see the messages that VControl controller was found and the VControl.xml configuration file was used.
Post by Michael » 14 Jan 2018 22:44
when the VBar controll is found, you have to configure it again in the joystick settings. It might be necessary to bring HELI-X in fatory settings before.
Thank you for your help.
andreyk72
Post by andreyk72 » 15 Jan 2018 14:40
Oh, It was my mistake. I was confused with the fact that when I go to controller->Sticks the bars are not moving on the first screen. Sorry for disturbing.
Does Heli-X6 license match Heli-X7?
