1724
Post by Michael » 10 Dec 2017 14:32
you may update to version 1724.
We have included some new features for fpv racing. You can see them in the sports hall with racing scene (which does not work with Version 6 or the previous revision of version 7.) The timer display will now track your times in fpv flight. And you can see what HELI-X thinks should be the next track point.
Anyone interested to design some new fpv racing tracks?
Hav fun and thank you for your feedback.
cristianpark
Re: 1724
Post by cristianpark » 10 Dec 2017 21:59
Hi Michael, can you please point me to the download of this Beta version for Linux? I can help in spanish translation if there's anything left to translate. Thanks for releasing this!!!
Re: 1724
Post by Michael » 11 Dec 2017 20:51
... please check your mailbox ...
danieldh206
Re: 1724
Post by danieldh206 » 17 Dec 2017 18:53
OSX 10.12.6
iMac 12,1
12 GB ram
On initial startup of Heli-Xv7, the OSX app security took over 4 minutes to initiate the "run program anyway" in security and privacy. I did not see any log errors or high CPU utilization during the 4 minutes. Please let me know of any test scenarios you would like me to run on my Mac.
In the non-beta versions is it cost effective to become an Apple identified developer?
Real Flight and neXt have some VR capabilities, how difficult are basic VR capabilities to deploy on Windows version of Heli-X?
danieldh206
chrig
Re: 1724
Post by chrig » 18 Dec 2017 21:43
Bin seit heute auch mit der V7 am testen.
- Installation problemlos
- Bei der Steuerungskonfiguration ist das Program 2 Mal abgestürtzt. Keine Ahnung warum, ist einfach eingefrohren und ich musste es mit dem TskMgr beenden. Die Konfiguration der Steuerung ist bei mir aber immer so eine Sache. Verwende Spektrum und RX2SIM. Ein Schalter Signal flippert bevor das Ganze konfiguriert ist immer. Beim 3. Anlauf war die Konfiguration erfolgreich.
- Erste Flüge mit Grundeinstellung geflogen und es funktioniert alles wie mit der V6.
Gruss,
chrig
Re: 1724
Post by Michael » 18 Dec 2017 22:27
thansk for your feedback.
V7 is based on a new revision of a graphics libarary. It allows the support of VR hardware, so it might come in the future.
The first start of HELI-X on a Mac takes longer, since many files are copied in the personal library folder. Maybe, the delay time came from this?
chrig
Re: 1724
Post by chrig » 19 Dec 2017 08:55
Hi Michael,
Since I also fly race copter I did a first try in Heli-X.
Is there a model that should fly like a real race copter.
I have never used Heli-X to fly FPV.
Compared to a current dedicated drone racing sim would have to be worked on the camera view (camera angle, FOV, noise, OSD).
Regards,
chrig
Gimli
Re: 1724
Post by Gimli » 19 Dec 2017 09:36
ich habe Heli-X auf Ubuntu 17.10 am laufen.
Soweit ich bisher (seit heute) testen konnte, funktioniert es ganz gut.
Allerdings, wenn ich FPV-Racing testen möchte, bekomme ich eine Fehlermeldung, sobald ich den Flugplatz FPV-Race auswähle.
Nach der Fehlermeldung stürzt Heli-X auch gleich ab.
Folgender Text steht in der Fehlermeldung:
Bezeichnung: "Error in application"
Meldung: "Uncaught exception thrown in Thread[jME3 Main,6,main]
NullPointerException"
Jörg
admin
Administrator
Re: 1724
Post by admin » 20 Dec 2017 00:20
bitte aktualisiere HELI-X, dass die nötigen Ressourcen geladen werden (Optionen->Update)
Gimli
Re: 1724
Post by Gimli » 20 Dec 2017 10:53
habe das Update machen lassen. Bei Kontrolle wurde mir angezeigt, dass das Programm auf dem aktuellen Stand ist.
Allerdings habe ich beim versuchten Laden des Flugplatzes "FPV Race" wieder die gleiche Fehlermeldung bekommen und das Programm stürzte ab.
Kann es vielleicht an meiner grenzwertigen Hardware-Voraussetzung liegen?
Intel Core2 Duo T6600 @ 2,20 GHz
4,0 GAB RAM
NVIDIA GeForce GT 230M
Wenn es zeitlich passt, werde ich auf meinem anderen Rechner (allerdings Win10 und bessere, aktuelle Hardware) weiter testen ("normal" Heli fliegen funktioniert auch unter Ubuntu)
Gruß Jörg
