1722
Post by Michael » 06 Dec 2017 00:30
Hello
you may update to revision 1722. New: Wind display for videos is correct in the wind display and the status line.
Have fun.
ilyxa
linux (ArchLinux latest)
Post by ilyxa » 08 Dec 2017 18:39
[ilyxa@wombat ~]$ uname -a
Linux wombat 4.14.3-1-ARCH #1 SMP PREEMPT Thu Nov 30 18:33:13 UTC 2017 x86_64 GNU/Linux
[ilyxa@wombat ~]$ archlinux-java status
Available Java environments:
  java-8-openjdk/jre
  java-9-jre/jre (default)
[ilyxa@wombat ~]$ java -version
java version "9.0.1"
Java(TM) SE Runtime Environment (build 9.0.1+11)
Java HotSpot(TM) 64-Bit Server VM (build 9.0.1+11, mixed mode)
[ilyxa@wombat ~]$
Every run this WARNING appears:
[ilyxa@wombat ~]$ /opt/HELI-X7/runHELI-X.sh
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.jme3.util.BufferUtils (file:/opt/HELI-X7/libs/jme/jme3-core.jar) to method sun.nio.ch.DirectBuffer.cleaner()
WARNING: Please consider reporting this to the maintainers of com.jme3.util.BufferUtils
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
But if i'm using openjdk-8/jre - there is no warning:
  java-8-openjdk/jre (default)
  java-9-jre/jre
If i'll try Fullscreen mode - Heli-x crashes (not a big deal):
handleError
SEVERE o 8:38:23 PM Uncaught exception thrown in Thread[jME3 Main,6,main]
java.lang.RuntimeException: Unable to find fullscreen display mode matching settings
        at com.jme3.system.lwjgl.LwjglDisplay.createContext(LwjglDisplay.java:79)
        at com.jme3.system.lwjgl.LwjglDisplay.runLoop(LwjglDisplay.java:180)
        at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.java:232)
        at java.base/java.lang.Thread.run(Unknown Source)
Test paltform for Beta: MacOSX 10.8 / MBP lat 11, Win 7 x64 / Lenovo X220 / MacOSX 10.9 / MBA late 12
Re: 1722
Post by Michael » 09 Dec 2017 21:53
thanks, this is a known problem of the jMonkeyEngine with Java 9.
They solved it, but it is not in the stable release. Thus, for the moment I keep it that way, and the users should use Java 8, which is included in the Mac and Windows Distribution.
You might try Java 8 from Oracle to see if your full screen display works.
Thank you for your feedback.
