1591
Postby Michael » 01 Feb 2015 09:14
you may update. New:
1. Parameter AutoTextureSeconds now works also with times down to 0.1
2. Pitch and Thrust Curves should be work correctly in the edit window.
Thank you for your feedback.
PS. Not every update path to 1591 is possible. Wehn you encounter difficulties, please downlaod the demo version again.
wolferl
Re: 1591
Postby wolferl » 01 Feb 2015 09:51
Michael,
tried 3 x the download... The 64bit file is corrupt.
Please upload again - Thanks
Wolfgang
Re: 1591
Postby Michael » 01 Feb 2015 10:12
Please try again, I just did the upload of the Windows files ...
bas756
Re: 1591
Postby bas756 » 01 Feb 2015 11:20
Hello Michael,
Tested 1591:
1. Pitch and Thrust Curves are working fine in the edit window now, thanks!
2. Found a new issue in 1591 in Windows 8.1 64bit. When I minimize the full screen simulation using ALT-TAB and trying to open it again I get a black screen and have to close and restart Heli-X. I have re-tested version 1590. (and also the older 1576). In these versions there is no problem when switching back to open a minimized full screen simulation!
Gruß :)
Patric
Re: 1591
Postby Michael » 01 Feb 2015 12:42
bas756 wrote: Found a new issue in 1591 in Windows 8.1 64bit. When I minimise the full screen simulation using ALT-TAB and trying to open it again I get a black screen and have to close and restart Heli-X. I have re-tested version 1590. (and also the older 1576). In these versions there is no problem when switching back to open a minimised full screen simulation!
Hello
does anobody else has these problems. I cannot realize them on my system, nor do I know what changes could cause this.
Thanks.
bas756
Re: 1591
Postby bas756 » 01 Feb 2015 15:20
Hi Michael,
I have tested more this 'black screen issue after minimize full screen on W64 in 1591'
I have found that between version 1590 and version 1591 I have changed a setting: "Pause when lost focus"
With this General Setting checked the problem 'black screen after minimize full screen simulation' occurs
I can now generate this issue also in version 1590 and previous (tested 1576)
When option not checked and after restart: minimizing and opening full screen simulation again is working fine.
Patric
wolferl
Re: 1591
Postby wolferl » 01 Feb 2015 17:04
Win 7/x64
I can not reproduce this 'black screen bug'.
Minimizing from full screen, partial screen or Alt-Tab to other SW - and activating the 1591 again,
it comes back as supposed to be!
greetings
Wolfgang
P.S. a nice feature this stop on lost focus. One day I will wade through all the menus and find more treasures :D
fabfour
Re: 1591
Postby fabfour » 05 Feb 2015 20:21
Hello Michael,
I had this exceptions today.
Sadly I did not notice when it happened. I saw them after closure of HELI-X.
Nevertheless i hope this helps
WARNUNG Logger 20:07:52 Exception thrown by;EventService topic subscriber:de.lessvoid.nifty.Nifty$ClassSaveEventTopicSubscriber@cf87aa{controllerButtonOk}{net.HeliX.a.ye@11a87dd}{class de.lessvoid.nifty.controls.ButtonClickedEvent}. Subscriber class:class de.lessvoid.nifty.Nifty$ClassSaveEventTopicSubscriber
org.bushe.swing.exception.SwingException: Exception handling event event class=none, event=null, topic=controllerButtonOk, eventObj=de.lessvoid.nifty.controls.ButtonClickedEvent@1508dd9
at org.bushe.swing.event.ThreadSafeEventService.handleException(ThreadSafeEventService.java:2021)
at org.bushe.swing.event.ThreadSafeEventService.onEventException(ThreadSafeEventService.java:1999)
at org.bushe.swing.event.ThreadSafeEventService.publish(ThreadSafeEventService.java:982)
at org.bushe.swing.event.ThreadSafeEventService.publish(ThreadSafeEventService.java:920)
at de.lessvoid.nifty.Nifty.publishEvent(Nifty.java:233)
at de.lessvoid.nifty.controls.button.ButtonControl$1.onEvent(ButtonControl.java:56)
at de.lessvoid.nifty.controls.button.ButtonControl$1.onEvent(ButtonControl.java:53)
at de.lessvoid.nifty.Nifty$ClassSaveEventTopicSubscriber.onEvent(Nifty.java:1404)
at org.bushe.swing.event.ThreadSafeEventService.publish(ThreadSafeEventService.java:980)
at de.lessvoid.nifty.elements.PrimaryClickMouseMethods.publishEvent(PrimaryClickMouseMethods.java:53)
at de.lessvoid.nifty.elements.PrimaryClickMouseMethods.onClick(PrimaryClickMouseMethods.java:26)
at de.lessvoid.nifty.elements.ElementInteractionClickHandler.onClickMouse(ElementInteractionClickHandler.java:108)
at de.lessvoid.nifty.elements.ElementInteractionClickHandler.process(ElementInteractionClickHandler.java:70)
at de.lessvoid.nifty.elements.ElementInteraction.process(ElementInteraction.java:79)
at de.lessvoid.nifty.elements.Element.mouseEvent(Element.java:1602)
at de.lessvoid.nifty.screen.MouseOverHandler.processMouseEvent(MouseOverHandler.java:105)
at de.lessvoid.nifty.screen.Screen.forwardMouseEventToLayers(Screen.java:369)
at de.lessvoid.nifty.screen.Screen.mouseEvent(Screen.java:337)
at de.lessvoid.nifty.Nifty.forwardMouseEventToScreen(Nifty.java:308)
at de.lessvoid.nifty.Nifty.access$1600(Nifty.java:77)
at de.lessvoid.nifty.Nifty$NiftyInputConsumerImpl.processEvent(Nifty.java:1373)
at de.lessvoid.nifty.Nifty$NiftyInputConsumerImpl.processMouseEvent(Nifty.java:1329)
at com.jme3.niftygui.InputSystemJme.handleMouseEvent(InputSystemJme.java:124)
at com.jme3.niftygui.InputSystemJme.onMouseButtonEventQueued(InputSystemJme.java:232)
at com.jme3.niftygui.InputSystemJme.forwardEvents(InputSystemJme.java:296)
at de.lessvoid.nifty.Nifty.update(Nifty.java:288)
at com.jme3.niftygui.InputSystemJme.endInput(InputSystemJme.java:113)
at com.jme3.input.InputManager.processQueue(InputManager.java:819)
at com.jme3.input.InputManager.update(InputManager.java:883)
at com.jme3.app.Application.update(Application.java:604)
at net.HeliX.j.j.update(Unknown Source)
at net.HeliX.j.b.update(Unknown Source)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.runLoop(LwjglAbstractDisplay.java:151)
at com.jme3.system.lwjgl.LwjglDisplay.runLoop(LwjglDisplay.java:185)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.java:228)
Caused by: java.lang.ArrayIndexOutOfBoundsException: -1
at net.HeliX.a.fk.c(Unknown Source)
at net.HeliX.a.fk.b(Unknown Source)
at net.HeliX.a.ye.onEvent(Unknown Source)
... 35 more
org.bushe.swing.exception.SwingException: Exception handling event event class=none, event=null, topic=controllerButtonOk, eventObj=de.lessvoid.nifty.controls.ButtonClickedEvent@376ed0
... 35 more
WARNUNG Logger 20:08:04 Exception thrown by;EventService topic subscriber:de.lessvoid.nifty.Nifty$ClassSaveEventTopicSubscriber@cf87aa{controllerButtonOk}{net.HeliX.a.ye@11a87dd}{class de.lessvoid.nifty.controls.ButtonClickedEvent}. Subscriber class:class de.lessvoid.nifty.Nifty$ClassSaveEventTopicSubscriber
org.bushe.swing.exception.SwingException: Exception handling event event class=none, event=null, topic=controllerButtonOk, eventObj=de.lessvoid.nifty.controls.ButtonClickedEvent@209dc8
... 35 more
org.bushe.swing.exception.SwingException: Exception handling event event class=none, event=null, topic=controllerButtonOk, eventObj=de.lessvoid.nifty.controls.ButtonClickedEvent@1d0decf
... 35 more
Re: 1591
Postby Michael » 05 Feb 2015 21:57
Thanks. Should be fixed in 1593.
Return to “V6 Beta Testing”
Who is online
