1582
Postby Michael » 24 Jan 2015 22:49
you may update to rev 1582. New:
1. No double shadows in hover training
2. No double shadows on the ground pointer
3. Hover trainings also works with multicopters.
Thank you for your feedback.
dudabsb
Re: 1582
Postby dudabsb » 25 Jan 2015 14:57
Dear Michael,
I arrived today. Where can i download this version?
Thanks for attention,
Eduardo
Re: 1582
Postby ThomasC » 27 Jan 2015 22:40
Haven't been testing very much in the last days, but one thing I noticed: on each start, the main window decreases it's size a little bit, so the window becomes smaller and smaller. Not much of an issue since fullscreen is functional (and in fact, it is!), but I wanted to point this out..
howard
Re: 1582
Postby howard » 28 Jan 2015 01:12
Hi Michael
I had a crash today when I plugged the HDMI ports into my TV, I have done this before with no issue..
The message is to long to post here. will email it
Cheers
Howard
Process: java [1699]
Path: /Library/Java/JavaVirtualMachines/jdk1.8.0_25.jdk/Contents/Home/bin/java
Identifier: net.heli-x.heli-x
Version: 1.0 (1.0)
Code Type: X86-64 (Native)
Parent Process: bash [1694]
Responsible: bash [1694]
User ID: 501
Date/Time: 2015-01-28 10:08:22.422 +1000
OS Version: Mac OS X 10.10.1 (14B25)
Report Version: 11
Anonymous UUID: 93EF0AFE-8937-F96C-8E72-8338851EC82C
Sleep/Wake UUID: 169B5740-4A56-4EDB-AF9D-52010DED5E00
Time Awake Since Boot: 53000 seconds
Time Since Wake: 450 seconds
Crashed Thread: 19 Java: Java2D Queue Flusher
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
VM Regions Near 0:
__TEXT 000000010fe56000-000000010fe67000 [ 68K] r-x/rwx SM=COW /Library/Java/JavaVirtualMachines/jdk1.8.0_25.jdk/Contents/Home/bin/java
Application Specific Information:
abort() called
Thread 0:: AppKit Thread Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff8c04252e mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff8c04169f mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff84cedb14 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff84cecfdb __CFRunLoopRun + 1371
4 com.apple.CoreFoundation 0x00007fff84cec838 CFRunLoopRunSpecific + 296
5 com.apple.HIToolbox 0x00007fff86d5043f RunCurrentEventLoopInMode + 235
6 com.apple.HIToolbox 0x00007fff86d501ba ReceiveNextEventCommon + 431
7 com.apple.HIToolbox 0x00007fff86d4fffb _BlockUntilNextEventMatchingListInModeWithFilter + 71
8 com.apple.AppKit 0x00007fff85b506d1 _DPSNextEvent + 964
9 com.apple.AppKit 0x00007fff85b4fe80 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 194
10 libosxapp.dylib 0x00000001273b642a -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] +
Re: 1582
Postby Michael » 28 Jan 2015 23:08
ThomasC wrote:Haven't been testing very much in the last days, but one thing I noticed: on each start, the main window decreases it's size a little bit, so the window becomes smaller and smaller. Not much of an issue since fullscreen is functional (and in fact, it is!), but I wanted to point this out..
Hello
on which operating system?
bas756
Re: 1582
Postby bas756 » 29 Jan 2015 07:37
I found serveral issues testing Flightmode curves just now.
- I can not save modified pitchcurve idle-up1.
- Loading a modified flightcurve and click OK, opening again flightmode menu and loaded flightcurves are changed back to others values.
- When I save a new flightcurve and I would like to load it, the name of he file is not visual in the menu untill I restart Heli-X
- In the folder miscellaneous/curves there are some testfiles together with the standardfiles. I did not create them, are these in the install set?
(see added screenshot)
PS1: I have litlle time this morning to test flightcurves in detail but if necessary I will test more this evening.
PS2: I have noticed, because ThomasC wrote, that my window in Heli-X also has become smaller (Win64)
But I change immediately to full screen after startup, so i did not take attention.
Kind regards, Patric
Re: 1582
Postby ThomasC » 29 Jan 2015 08:47
Hello
Win7-64
howard
Re: 1582
Postby howard » 29 Jan 2015 12:29
Hi Michael
Before I test I normally check if there is a new version, it updated to 1584 I think but when I run it I get an error I will mail it to you
Cheers
Howard
howard
Re: 1584
Postby howard » 29 Jan 2015 20:56
Version is looking good so far not tested everything..
The mouse pointer is now gone on my mac as it should in full screen mode and still there in normal mode..
Just a side note, Heli-X uses around 45% of the CPU on my Macbook, so it is very heavy on the machine..
Cheers
Howard
Winger69
Re: 1582
Postby Winger69 » 29 Jan 2015 23:19
auch bei mir verkleinert sich das Fenster bei jedem Neustart von Rev. 1582 - und was mir auch aufgefallen ist, wenn ich in den Fullscreen-Modus wechsle stottert das Bild.
Wenn ich Heli-x dann beende, neustarte und dann wieder in den Fullscreen wechsle läuft´s vollkommen ohne ruckeln. Es ist dann auch egal was noch so im Hintergrund läuft
Torsten
System for BETA Test: INTEL i7 4770 CPU / 3,40 GHz / WIN 7 64bit / 8GB / NVIDIA GTX 660 / GFX driver 344.60 vom 15.11.2014 / Monitor LG 34UC97
Return to “V6 Beta Testing”
Who is online
