1578
Postby Michael » 15 Jan 2015 08:42
some of you had problems with theuser interface that the mouse pointer had to be positioned some pixels away from the buttons... This should be fixed in 1578
Thank you for your feedback.
jk6stringer
Re: 1578
Postby jk6stringer » 15 Jan 2015 23:08
I am still seeing the issue with downloading Airports where the last 2 at the bottom of the list are not selectable. I thought I would post a pic to visualize this. This changes depending on which airports are available so I dont think that it is the particular airport more the last 2 in the list.
Airport not selectable
Airport Not Selectable.png (85.78 KiB) Viewed 1386 times
bas756
Re: 1578
Postby bas756 » 16 Jan 2015 20:55
Tested 1578, installation, simulation .... OK
I have extra checked mouse positioning (windowed and full screen) .... OK (top on the pixel)
It was allready OK on my system (Win 8.1) in previous (recent) versions.
Gruß :)
Patric
Re: 1578
Postby Michael » 16 Jan 2015 22:19
jk6stringer wrote:I am still seeing the issue with downloading Airports where the last 2 at the bottom of the list are not selectable. I thought I would post a pic to visualize this. This changes depending on which airports are available so I dont think that it is the particular airport more the last 2 in the list.
These airports will not be part of the distribution. So this will be not a problem.
Thanks.
Re: 1578
bas756 wrote:Tested 1578, installation, simulation .... OK
Gruß :)
Patric
Thanks!
Return to “V6 Beta Testing”
Who is online
