1574
Postby Michael » 11 Jan 2015 01:02
revision 1574 is available. Changes:
1. When the controller settings was called, the drag of HUD dispplays was not possible. This should work now.
2. When the keyboards settings are changed and the keyboard display is open, the contents of the display is updated.
3. When HUDs were toggled, the drag of the HUD was unstable sometimes. This should work now.
4. New revision management for the update of resources (not testable for you).
Thank you for your help.
angerha
Re: 1574
Postby angerha » 11 Jan 2015 07:28
Sorry. Can't update to 1574. It says version is up to date.
System:
AMD Athlon(tm) 7550 Dual-Core Processor / 2,50 GHz / 4GB
Kubuntu 13.10 / Linux 3.13.0-41-generic
Radeon HD 6450
java version "1.8.0_25", build 1.8.0_25-b17
Re: 1574
Postby Michael » 11 Jan 2015 08:37
Now it shoould work, the upload is finished ... ;-)
angerha
Re: 1574
Postby angerha » 11 Jan 2015 10:02
It works now! :D
System:
Radeon HD 6450
Re: 1574
Postby ThomasC » 11 Jan 2015 10:26
so, now I decided to give some feedback, had time for testing this morning.
- screen "flickers" directly after loading airport (on program start or when changing airports)
- rotor "disc" sometimes disappears when flying in front of collision objects (trees, fences etc.)
- blade sound doesn't reflect current RPM when RPM drops too low (e.g. when autorotating) - makes autorotation by sound difficult (in Heli-X v4 this was working really good)
- two airports cannot be loaded: "Thurner" and "stoervetten-02"
- "Favourites" in Airport selection: has to be toggled twice before it works
- keyboard definition is not updated automatically when changing language - has to be closed and opened again
- windows cannot be closed by pressing ESC
- selection of Airport/Heli/Scene cannot be done by double clicking
- scrollbar movement is not pagewise when clicking above / below slider
more to follow :) - I really like the current v6 and have already stopped using v5
have fun and success
fabfour
Re: 1574
Postby fabfour » 11 Jan 2015 13:29
Just one small thing to add that i just noticed:
In multiplayermode while typing the chatwindow loses focus if another user changes his helicopter.
mackam
Re: 1574
Postby mackam » 11 Jan 2015 18:23
The statistics (usage time for example) on the current heli is not updated until I either switch to another heli or restart the program. It is not a big deal but it would be nice if this was updated each time I open the statistics window. Also rather than just have an overall time usage it would be nice to see the current session time per current heli as a separate statistic.
angerha
Re: 1574
Postby angerha » 11 Jan 2015 19:17
Airport and Heli selection:
If an airport or heli isn't currently available and has to be updated, it would be nice if just this airport or heli is preselected in the following update window or if it would be updated and loaded automatically. :)
Ok, I'll try this.
System:
Radeon HD 6450
Chris_toph
Re: 1574
Postby Chris_toph » 11 Jan 2015 19:35
Gerade update gemacht.Jetzt startet Heli-X nicht mehr
Gruß Christoph
Re: 1574
Postby Michael » 11 Jan 2015 22:02
Thank you. here are my comments:
Is a feature, this is the looking around to bring the airport images into the graphics adapter
A known and difficult problems of most graphics engines
This is a question of the mdoel settings. I suggest we try this on one or two models together vie email
My mistake. They are not part of the distribution
I check this
This is also true for some windows. Since the language is typically not changed very often. I'll keep this for simplicity.
I think this is not usually done. E.g. ESC is for me switching between full screen mode and windowed mode.
I'll check this, not sure if I can solve this. Pressing ENTER should work, though.
I'll check this.
Thank you for your help!
Return to “V6 Beta Testing”
Who is online
