1573
Postby Michael » 10 Jan 2015 11:12
you may update to rev 1573. Omly a few changes are made:
1. New icons in different resolutions
2. The switch from fullscreen and back is modified. Maybe that helps you, but the switch is always very dependent on the hardware and the drivers.
Thank you for your feedback.
ronk
Re: 1573
Postby ronk » 10 Jan 2015 11:56
Umschalten Fenster - Fullscreen und zurück funktioniert nun. Die eigenartige Wolkendarstellung hat sich damit auch erledigt... Super! Bei mir sieht soweit alles gut aus.
Gruß, der Ronny
Re: 1573
Postby Michael » 10 Jan 2015 12:16
Danke fürs Feedback!
fabfour
Re: 1573
Postby fabfour » 10 Jan 2015 13:51
Hi Michael,
auch bei mir funktioniert Fullscreen Mode nun mit Ubuntu 32-Bit
Top!
Winger69
Re: 1573
Postby Winger69 » 10 Jan 2015 14:47
Ja hallo,
auch bei mir funzt es nu - das mit dem Fullscreen an und aus :D :D
Super Sache - Vielen Dank
Torsten
System for BETA Test: INTEL i7 4770 CPU / 3,40 GHz / WIN 7 64bit / 8GB / NVIDIA GTX 660 / GFX driver 344.60 vom 15.11.2014 / Monitor LG 34UC97
bas756
Re: 1573
Postby bas756 » 10 Jan 2015 16:14
Hi Michael,
Tested 1573, working on Win64, full screen and windowed. Models are flying very good.
No remarks.
Kind regards
howard
Re: 1573
Postby howard » 10 Jan 2015 17:12
HI Michael
This is a great release. Models flying well Full Screen working very well on my Mac and performance is good..
I still cant turn off the Mouse no matter what I do.. and this on a macbook with a trackpad.. as I said I am on vacation in the USA so cant test it on my iMac..
Looking Good
Howard
howard
Re: 1573
Postby howard » 10 Jan 2015 17:37
Hi Michael
I thought I would starting testing a few other things now that the core and good and the weather is not great to Ski
Here is one for you..
If I go to Config and controller and then to keyboard definitions and add some more keys, if the keyboard "show keyboard" is on once I exit the menu the Keyboard definition on the screen is not refreshed with the new selection of key added. But also you now don't have the ability to move or resize any of the overlays on the screen, Even if you go an add something like show-G meter you cant move or resize it until you reload the entire application. The reason seems as you have moved focus to the menu as the menu bar is now active?
Howard
angerha
Re: 1573
Postby angerha » 10 Jan 2015 20:21
Yes I agree. 1573 is a cool release and makes fun! :D
But I have one issue:
Switching to Fullscreen works now. Great!
But i can't switch back to normal mode. HELI-X doesn't show the scene or heli. The content of the normal window is not shown at all. It just shows the content of the desktop or things that apeared on another window earlier, for example.
Screen modes in global settings menu are still shown with the postfix 1Bit, not more.
Java does not throw an exception!
Is there anyone out there with similar experiences?
Andre
System:
AMD Athlon(tm) 7550 Dual-Core Processor / 2,50 GHz / 4GB
Kubuntu 13.10 / Linux 3.13.0-41-generic
Radeon HD 6450
java version "1.8.0_25", build 1.8.0_25-b17
Return to “V6 Beta Testing”
Who is online
