1572
Postby Michael » 08 Jan 2015 22:56
you may update to revision 1572. You need 1571 before the update. If your version is older, please download the beta version 6.0 demo and activate it.
New:
1. Udpate mechanism should work.
2. Italian language. (To test the italian language, you have tu update twice.)
3. Helicopters with smoke should work again
4. Some of you mentioned, that HELI-X stucks after a few seconds. This could be removed now. Please let me know. (I try to transfer the whole scene in the graphics adapter after loading of the airport)
Thank you for your feedback.
bas756
Re: 1572
Postby bas756 » 09 Jan 2015 21:26
Hi Michael,
Updated from 1571 to 1572 ... OK.
Heli's with smoke are working again.... OK.
Loading whole scene in graphics adaptor can be observed after loading airport some flickering of the screen about one second , no crashes OK.
Flying in single player and multiplayer OK.
This version looks fine for me! (till now ;) )
Kind Regards, Patric
dklueh
Re: 1572
Postby dklueh » 09 Jan 2015 22:50
HI MIchael!
Seit der 72 startet Heli-X nicht mehr, habs vorher aber 'runter geschmissen, wie Du gesagt hast!
Exception in thread "AWT-EventQueue-0" java.util.MissingResourceException: Can't
find bundle for base name Translation/MessagesBundle, locale en_US
at java.util.ResourceBundle.throwMissingResourceException(ResourceBundle
.java:1564)
at java.util.ResourceBundle.getBundleImpl(ResourceBundle.java:1387)
at java.util.ResourceBundle.getBundle(ResourceBundle.java:845)
at net.HeliX.g.a.j(Unknown Source)
at net.HeliX.g.a.<init>(Unknown Source)
at net.HeliX.g.a.a(Unknown Source)
at net.HeliX.d.az.<init>(Unknown Source)
at net.HeliX.d.j.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:744)
at java.awt.EventQueue.access$400(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:697)
at java.awt.EventQueue$3.run(EventQueue.java:691)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDo
main.java:75)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:714)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThre
ad.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.
java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThre
ad.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
dklueh
Re: 1572
Postby dklueh » 09 Jan 2015 23:07
Nach Neuinstallation von Java7 geht's nun...
Return to “V6 Beta Testing”
Who is online
