1571
Postby Michael » 08 Jan 2015 09:14
there is another update.
You have to install the demo version first to make it work. This is due to the fact that the start scriot is changed for 1)
Changes:
1) Some ressources and language files are relocated to simplify the update process.
2) Using Shift/ALt etc. in the helicopter selection could cause an exception. This should be corrected now.
Thanks for your feedback (I'll look for the other issues mentioned).
angerha
Fullscreen funktioniert immer noch nicht
Postby angerha » 08 Jan 2015 15:06
Beim Umschaltversuch auf Fullscreen gibt es folgenden Fehler:
SCHWERWIEGEND b 14:59:30 Uncaught exception thrown in Thread[LWJGL Renderer Thread,6,main]
java.lang.RuntimeException: Unable to find fullscreen display mode matching settings
at com.jme3.system.lwjgl.LwjglDisplay.createContext(LwjglDisplay.java:79)
at com.jme3.system.lwjgl.LwjglDisplay.runLoop(LwjglDisplay.java:177)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.java:228)
Meine Auswahlmöglichkeiten bei der Bildgröße siehe hier:
Ist 1 Bit so richtig? Liegt hier der Fehler?
System:
AMD Athlon(tm) 7550 Dual-Core Processor / 2,50 GHz / 4GB
Kubuntu 13.10 / Linux 3.13.0-41-generic
Radeon HD 6450
java version "1.8.0_25", build 1.8.0_25-b17
howard
Re: 1571
Postby howard » 08 Jan 2015 17:09
Hi Michael
I installed the demo version as requested its now 1567 but when I try and run the upgrade option I get a warning dialog that says "Cannot get information about Updates" ?? The internet is working.. Hence this post.. What am I missing?
Howard
bas756
Re: 1571
Postby bas756 » 08 Jan 2015 19:38
Hi Michael,
I have installed first the demo version Win64. For me this demo version is now 1571. Registererd and downloaded Helicopters and Airports, configured controller. Configured Open GL screen resolution 3600x1920, no problems. Flying in simulatot with Logo 600SX no problem.
I think i have fould an error in this version:
I can not load bigger heli's: for example: AH-1Z, AS332SuperPuma, Lama, DNHPAirfox90AT, MD500, NH90
Reinstalled ... same problem, many errors in status window after trying to load a bigger heli. No heli is appearing.
Tested on dfferent airports
Retested version 1567 ...OK
Kind regards, Patric
Re: Fullscreen funktioniert immer noch nicht
Postby Michael » 08 Jan 2015 20:51
angerha wrote:Beim Umschaltversuch auf Fullscreen gibt es folgenden Fehler:
sind alle Farbtiefen 1Bit oder gibt es noch andere? Danke.
Re: 1571
Postby Michael » 08 Jan 2015 20:52
howard wrote:Hi Michael
Howard
After installing the demo, the revision should be 1571. Are you using an older version?
Re: 1571
Postby Michael » 08 Jan 2015 20:53
bas756 wrote:Hi Michael,
Do you get informations in the cmd window when you try to load the helicopters?
Thanks
Re: 1571 (64bit or 32bit)
Postby ThomasC » 08 Jan 2015 21:09
@Michael: is there any sense in installing the 64bit version? I have a 64 bit OS, but in the past found no differences when testing 32bit and 64bit, so I currently only test the 32bit version (have been busy these days so not much testing took place, but I will find more testing time from now on). I even found a good way to share the installed version between Ubuntu and Windows, which need complete different controller configurations, and under Ubuntu I have installed 32bit Java.
Re: 1571
Postby Michael » 08 Jan 2015 21:25
Thanks
I found it, problems make the helicopters with smoke. I'll fix it.
Postby Michael » 08 Jan 2015 21:27
ThomasC wrote:@Michael: is there any sense in installing the 64bit version? I have a 64 bit OS, but in the past found no differences when testing 32bit and 64bit, so I currently only test the 32bit version (have been busy these days so not much testing took place, but I will find more testing time from now on). I even found a good way to share the installed version between Ubuntu and Windows, which need complete different controller configurations, and under Ubuntu I have installed 32bit Java.
The only difference is the java version which comes with HELI-X (and which is used, also if you have your own Java installed). The 64 bit version might be faster or can use more memory. So I would use it.
Return to “V6 Beta Testing”
Who is online
