1571
bas756
Re: 1571
Postby bas756 » 08 Jan 2015 21:39
Michael wrote:
Michael wrote:
bas756 wrote:Hi Michael,
I have installed first the demo version Win64. For me this demo version is now 1571. Registererd and downloaded Helicopters and Airports, configured controller. Configured Open GL screen resolution 3600x1920, no problems. Flying in simulatot with Logo 600SX no problem.
I think i have fould an error in this version:
I can not load bigger heli's: for example: AH-1Z, AS332SuperPuma, Lama, DNHPAirfox90AT, MD500, NH90
Reinstalled ... same problem, many errors in status window after trying to load a bigger heli. No heli is appearing.
Tested on dfferent airports
Retested version 1567 ...OK
Kind regards, Patric
Do you get informations in the cmd window when you try to load the helicopters?
Thanks
I found it, problems make the helicopters with smoke. I'll fix it.
I see you allready found it. Thanks!
I have attached two files maybe of some intrest.
Kind Regards, Patric
Startup1571.zip
(2.32 KiB) Downloaded 51 times
Re: 1571
Postby ThomasC » 08 Jan 2015 22:14
my favourite Heli (DNHP90AirfoxAT) doesn't load:
WARNUNG Logger 22:10:44 Exception thrown by;EventService topic subscriber:de.lessvoid.nifty.Nifty$ClassSaveEventTopicSubscriber@127a
f92{loadButtonOk}{net.HeliX.a.cr@135c082}{class de.lessvoid.nifty.controls.ButtonClickedEvent}.  Subscriber class:class de.lessvoid.nifty.Nifty$ClassSaveEventTopicSubscriber
org.bushe.swing.exception.SwingException: Exception handling event event class=none, event=null, topic=loadButtonOk, eventObj=de.lessvoid.nifty.controls.ButtonClickedEvent@87129a
        at org.bushe.swing.event.ThreadSafeEventService.handleException(ThreadSafeEventService.java:2021)
        at org.bushe.swing.event.ThreadSafeEventService.onEventException(ThreadSafeEventService.java:1999)
        at org.bushe.swing.event.ThreadSafeEventService.publish(ThreadSafeEventService.java:982)
        at org.bushe.swing.event.ThreadSafeEventService.publish(ThreadSafeEventService.java:920)
        at de.lessvoid.nifty.Nifty.publishEvent(Nifty.java:233)
        at de.lessvoid.nifty.controls.button.ButtonControl$1.onEvent(ButtonControl.java:56)
        at de.lessvoid.nifty.controls.button.ButtonControl$1.onEvent(ButtonControl.java:53)
        at de.lessvoid.nifty.Nifty$ClassSaveEventTopicSubscriber.onEvent(Nifty.java:1404)
        at org.bushe.swing.event.ThreadSafeEventService.publish(ThreadSafeEventService.java:980)
        at de.lessvoid.nifty.elements.PrimaryClickMouseMethods.publishEvent(PrimaryClickMouseMethods.java:53)
        at de.lessvoid.nifty.elements.PrimaryClickMouseMethods.onClick(PrimaryClickMouseMethods.java:26)
        at de.lessvoid.nifty.elements.ElementInteractionClickHandler.onClickMouse(ElementInteractionClickHandler.java:108)
        at de.lessvoid.nifty.elements.ElementInteractionClickHandler.process(ElementInteractionClickHandler.java:70)
        at de.lessvoid.nifty.elements.ElementInteraction.process(ElementInteraction.java:79)
        at de.lessvoid.nifty.elements.Element.mouseEvent(Element.java:1602)
        at de.lessvoid.nifty.screen.MouseOverHandler.processMouseEvent(MouseOverHandler.java:105)
        at de.lessvoid.nifty.screen.Screen.forwardMouseEventToLayers(Screen.java:369)
        at de.lessvoid.nifty.screen.Screen.mouseEvent(Screen.java:337)
        at de.lessvoid.nifty.Nifty.forwardMouseEventToScreen(Nifty.java:308)
        at de.lessvoid.nifty.Nifty.access$1600(Nifty.java:77)
        at de.lessvoid.nifty.Nifty$NiftyInputConsumerImpl.processEvent(Nifty.java:1373)
        at de.lessvoid.nifty.Nifty$NiftyInputConsumerImpl.processMouseEvent(Nifty.java:1329)
        at com.jme3.niftygui.InputSystemJme.handleMouseEvent(InputSystemJme.java:124)
        at com.jme3.niftygui.InputSystemJme.onMouseButtonEventQueued(InputSystemJme.java:232)
        at com.jme3.niftygui.InputSystemJme.forwardEvents(InputSystemJme.java:296)
        at de.lessvoid.nifty.Nifty.update(Nifty.java:288)
        at com.jme3.niftygui.InputSystemJme.endInput(InputSystemJme.java:113)
        at com.jme3.input.InputManager.processQueue(InputManager.java:819)
        at com.jme3.input.InputManager.update(InputManager.java:883)
        at com.jme3.app.Application.update(Application.java:604)
        at net.HeliX.j.j.update(Unknown Source)
        at net.HeliX.j.b.update(Unknown Source)
        at com.jme3.system.lwjgl.LwjglAbstractDisplay.runLoop(LwjglAbstractDisplay.java:151)
        at com.jme3.system.lwjgl.LwjglDisplay.runLoop(LwjglDisplay.java:185)
        at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.java:228)
Caused by: com.jme3.asset.AssetNotFoundException: /plasma1.png (Flipped) (Mipmapped)
        at com.jme3.asset.DesktopAssetManager.loadAsset(DesktopAssetManager.java:283)
        at com.jme3.asset.DesktopAssetManager.loadTexture(DesktopAssetManager.java:346)
        at com.jme3.asset.DesktopAssetManager.loadTexture(DesktopAssetManager.java:356)
        at net.HeliX.b.i.b.<init>(Unknown Source)
        at net.HeliX.b.i.c.<init>(Unknown Source)
        at net.HeliX.f.h.p(Unknown Source)
        at net.HeliX.r.b.a(Unknown Source)
        at net.HeliX.j.b.y(Unknown Source)
        at net.HeliX.d.az.a(Unknown Source)
        at net.HeliX.a.ahn.p(Unknown Source)
        at net.HeliX.a.ahn.i(Unknown Source)
        at net.HeliX.a.cr.onEvent(Unknown Source)
        ... 35 more
edit: I see the problem has already been identified, so please ignore my posting :)
howard
Re: 1571
Postby howard » 09 Jan 2015 00:25
When I install the mac version from the link you sent , I get version 1567 and I cant update it??
Howard
Re: 1571
Postby Michael » 09 Jan 2015 07:28
howard wrote:Michael
Howard
Sorry, please try again. If it does not work, delete your HELI-X6 folder in the personal library folder and then try again.
howard
Re: 1571
Postby howard » 09 Jan 2015 07:54
all working now :-))
Return to “V6 Beta Testing”
Who is online
