Mixing gas and pitch
Albator
Post by Albator » 20 Aug 2014 15:45
Is it possible to mix gas and pitch in Heli-5 ?
Thanks for your help.
Regards
Re: Mixing gas and pitch
Post by JS1 » 20 Aug 2014 16:26
There is both throttle and pitch curves in Heli-X to control both accordingly.
Albator
Post by Albator » 20 Aug 2014 19:52
Ok I will try to see where this parameter is. If you can tell me where you have it can be good also.
Thanks
Post by JS1 » 21 Aug 2014 12:28
Just check the menu. It's right there under "Flight modes". If you are not used to this kind of curves, there's a ton of good reads in the internet for CP helis. It will work exactly the same with any decent transmitter to control a real CP model's throttle and pitch.
