Page 3 of 4
Re: Modeling Log: GAUI X7 for HELI-X
Posted: 27 Jul 2013 14:07
by JS1
Posted: 07 Aug 2013 17:20
by velocity90
Very nice
Cant wait to try it. Is it easy to change blades or is this something that isnt easy to do by myself?
Posted: 07 Aug 2013 23:12
by JS1
velocity90 wrote:Is it easy to change blades or is this something that isnt easy to do by myself?
Changing the looks only for yourself is easy. Just locate the texture image (MainR.jpg) in the model folder and adjust it using a paint program. Also do the same with the texture files for the spinning rotor disc (top.png and bottom.png). The spinning textures must be .png and have a suitable transparency.
But to have it changeable and available for all is a different story and basically not possible. You could define the rotors as Texture Shape and set the texture files in the .xml - BUT, even this would have no effect on switching the looks of the spinning rotor disc.
Posted: 08 Aug 2013 19:48
by velocity90
Thank you for your answer. Adjusting using a paint program is almost inpossible for me. How do I make a proper usable file from a set of real blades ( Rail 696) or just a picture of them. What angle? All magic to me
Posted: 09 Aug 2013 18:49
by JS1
Hm, I fear that to make a usable picture file the usage of a picture editing program is unavoidable...
Posted: 10 Aug 2013 08:41
by velocity90
Ok, im not skilled with those. I will fly them as they are
Is the bright red/yellow one also coming?
http://t1.gstatic.com/images?q=tbn:ANd9 ... 9kB2uhOgHA
Posted: 10 Aug 2013 16:47
by JS1
Thanks for the input. Maybe I'll add it at a later stage but at the moment too busy with new models
Posted: 12 Sep 2013 20:44
... now available for download ...
- Thanks to Torsten ...
- GauiX7.jpg (250.88 KiB) Viewed 15947 times
Posted: 26 Sep 2013 17:37
by groovebass
Please write me where i can download these GAUI X7, greetings uli
Posted: 27 Sep 2013 08:06
by JS1
It will be available with HELI-X 5.
Then you can download/update it anytime from within the Sim using the "Look for new helicopters" menu item.
