Hi
I have been using Heli-x without any issue on Mountain Lion, but when testing Mavericks, currently on DP6, the controller is not working.
Somehow it is detected, when i have it plugged in, Heli-x does not complain about any missing controller, but when trying to calibrate the controller, the sticks or switches are not detected at all.
If i remove the controller and restart Heli-x, i get the "No controller is found" message.
The controller is the Interlink Elite i use for Realflight, it was working perfectly under Mountain Lion/Heli-x before upgrading to Mavericks. The rest of hell-x seems to work.
Best
Emilio
Heli-X on Mavericks DP6
Re: Heli-X on Mavericks DP6
I am not sure if I can help. You might try to bring HELI-X to the factory settings and then try again.
Thanks Michael; i reinstalled helix from scratch to test it with no luck.
Anyway i can use the sim in my MountainLion computer with no trouble, this is more for you to know in case you need to adapt or fix something to make it work under Mavericks or need some testing under it.
Thanks
Emilio
Thanks
Emilio
On Mavericks Héli-X recognise my controller but the screen stay black. I notice during the start of Heli-X the window of Heli-X was blinking 4 times. This was not the case on Mountain Lion. Visibly, Heli-X do not work on Mavericks.
I try to set the factory default. Nothing change, always black window.
Also if you change parameter, that request a restart. Heli-X crash trying to restart.
Which java version are you using?
Java 6 should work.
Java 6 should work.
I use what is loaded by the official Apple Mavericks software. Heli-X must use the standard or include inside Heli-X any non standard software.
I do not even know where is indicated the java version and where Java is store.
