Works great. Currently using a plain acro model but 1 servo swash should work also.
Tried it on a Mini and an iMac. Still sorting out switches and channels but the basics are pretty easy to get working.
Spektrum DX18 and Mile High Wings interface
Re: Spektrum DX18 and Mile High Wings interface
One thing to note, the new firmware that enables 2048 resolution (Version 2+) does not work with Heli-X at this time.
The 1024 bit firmware 1.54 works fine.
What happens? Do you get the message "no controller found"?
That is correct, the message is no controller found.
With the 1.54 firmware (1024 bit) It is recognized but with 2.01 the controller is not seen.
The USB interface has a different name with the new firmware so I assume it has something to do with that.
