Heli-X Closes on Launch - OSX
Beitragvon 4n6Days am Mi 28. Jul 2010, 01:10
I have a macbook running OSX 10.5. I had installed the Heli-X demo a while ago and tonight, I tried to install 3.0 and see how it ran on the mac.
When I click on the program it starts to launch, the splash screen comes up for a second then it closes.
4n6Days
Re: Heli-X Closes on Launch - OSX
Beitragvon Michael am Mi 28. Jul 2010, 12:17
there was a problem with "old" 2.0 version, and I guess you are launching it.
You should remove COMPLETELY the old version including the personal library folder, then install 3.0 again. The first start takes some time.
Benutzeravatar
Beitragvon radekdomin am Do 29. Jul 2010, 23:18
Hello. Today I started having the same problem. I'm using HELI-X since July 7th already. I haven't installed any older version. Everything was working so far. But now it crashes a few sec after it starts.
Following some information from system log. It may hel you:
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000246007758
Crashed Thread: 21 Java: AWT-EventQueue-0
Java information:
Exception type: Bus Error (0xa) at pc=1503ab72a
If the entire log would help you, I can send it to you.
radekdomin
Beitragvon Michael am Do 29. Jul 2010, 23:42
You mean it worked for three weeks but now it crashes?
Please send me the complete output of the console window, if possible.
Benutzeravatar
Beitragvon radekdomin am Fr 30. Jul 2010, 00:17
Michael hat geschrieben:You mean it worked for three weeks but now it crashes?l
Yes, thats right. I've sent you and email with detailed logs.
Thanks for helping me with this Michael.
radekdomin
Beitragvon Michael am Fr 30. Jul 2010, 11:56
the log descibes problems in org.tritonus.share.sampled.file.TAudioFileReader
These are problems with the ambient sound. It might be, that this was the first time you used an airport with ambient sounds or you switched them on, or the native libs on your Mac have changed ....
You should switch off the ambient sound. This could be done in Settings->Performance if HELI-X was running ... ;-)
Thus, delete the file files/Application/ApplicationSettings.xml
After that, the ambient sound is switched off.
Benutzeravatar
Beitragvon radekdomin am Mo 2. Aug 2010, 10:30
It worked! Great support :-) I didn't even realized this could have something to do with ambient sound settings. Thanks a lot Michael.
radekdomin
Beitragvon radekdomin am Mo 2. Aug 2010, 22:59
Hm. I started having problems again during next start. So I've decided trying deleting all HELI-X folder from my local Library. Now it looks I'm having with activation full version. Do you check it online and allow only one activation? If so is there any chance to reset my activation so I can activate it again?
Username: "Radek Domin (Prague)"
radekdomin
Beitragvon Michael am Di 3. Aug 2010, 18:58
You have Email ...
Benutzeravatar
Beitragvon radekdomin am Di 3. Aug 2010, 23:30
Huge thanks to you Michael. I've never seen such a good customer service. This is just awesome. Thank you very much for your speed as well as for your patience.
radekdomin
Zurück zu HELI-X on Mac OS-X
Wer ist online?
Mitglieder in diesem Forum: 0 Mitglieder und 1 Gast
cron
